LG DA-3525 Theater System Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
  • Anonymous Mar 30, 2014
    LG sound bar is working.However,no sound from the subwoofer.Have noticed a blinking red light beside the digital display on the sound bar.Is this indicating a problem?
Marshall
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Habit-Forming:
  • Contributor 3 Answers
  • Posted on Mar 18, 2022
Marshall
Contributor
Level 1:
Mentor:
Habit-Forming:
Answers
Questions
0
Helped
1120
Points
60
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Feb 19, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73392
Points
482
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
1helpful
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
My sub woofer in my car won't turn on , how do I
you will need to establish what the cause is if it is a factory fitted unit and your car 2002 or newer it will have diagnostic plug in the right hand foot well just under the dash this is called OBD2 socket a reputable garage will have the equipment to plug in and read the codes back from your car and should display your sub woofer problem, if this is self fitted then it a case of tracing your circuits and testing your amps good luck
Hi there the sub woofer for my lg lht550 home cinema system is not working. I then bought a new sub woofer from ebay, still an LG and put that into the system and thats not working either, Im now...
Check the marking of the connection of your tv if it is audio out if still not working check the setting, go to main menu of your tv then try to look for external audio input then try to configure the setting.
1helpful
2answers
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
2answers
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
I do not know how to connect the woofer KEF PSW3500 to the amplifier Denon 4310. BCC sold me a 1 on 1 plug, but the woofer needed to plugs (left and right).
Bass is mono directional in the main,and while your sub has a left and right input ( because a few amps do have left and right sub outs) only one of them is required (usually marked as MONO on the sub). You can also get a Y splitter phono adapter and connect the single cable you have to both sockets, which is how I have mine set up. This is most common
1helpful
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
My speakers only work one at a time...
Check you have plugged them into the correct socket on the back of the PC ..
Chances are you have 3 sockets - first = 'front' (or pair), middle = 'back' (for 4+ speaker sets) and last = 'center & sub-woofer' ..
Sounds like you have plugged into the 'center & sub-woofer' socket :-)
1helpful
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 • JVC RX-778V
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
