Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: I replaced four Marine batteries
I know you said you checked all the fuses, how about the one on the back of the head unit. I just had this happen to me in my truck. I changed the battery and dead radio. the fuses in the fuses box where fine so i had to pull the radio and replace the fuse on the back of the head unit. You will find the fuse under the gang plug. if you can't get to the back side of the radio you will need to pull it out. You can get the keys if you don't have them at your local audio shop ( best buy, or a local shop ) you will have to take you face plate off and trim ring. on the side of the radio yo will sluts one per side slide the keys in till you hear it click. them pull the keys out and the radio should follow. The fuse in the rear of the radio should be a mini blade 10amp fuse.
Let me know what you find and if you need more help please feel free contact me.
M.Woodring
