Sony KP-57WS500 57" Rear Projection Television Logo
Anonymous Posted on Feb 19, 2011
I've replaced my STK's, 2 pico fuses on the G boards, and tested each convergence resistor along with the pico fuses on the D board--albeit they were still soldered in place. I desoldered two pico fuses and one resistor to test them in said manner, but they checked out fine. I've gone over every square millimeter around the soldered area of each STK with a microscope checking for areas with missing solder. Even the tiny surface mount resistors are intact. My hopes were really high in getting this TV fixed. I must be missing something--can anyone point out some idears please? Thanks, Kris
Anonymous
Level 2:
Novelist:
  • Expert 99 Answers
  • Posted on Feb 19, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
99
Questions
Helped
15938
Points
210
I believe there is a power board on the left side when looking from the back. It will be vertical, right next to the board you worked on. Take that board out. I believe there are about four pico fuses on that board. One or two of them will be open. Replace the fuses and you should be good to go.
  • Anonymous Feb 19, 2011
    Gtech man,
    I found 2 pico fuses on that board were bad, but figured there were only the 2. I will double-check for more and report back. Thanks for the help!
I Change the two stk for the convergence but steel have troubles
most sony models require the 6 pico fuses on the D board and the 2 Picos on the G board will require replacement along with the two ICs. Did you check the pico fuses?
My TV is showing convergence symptoms: the screen looks like 3D effects and as if someone is pusing in the middle of the screen. I've replaced my STK's, 2 pico fuses on the G board, and tested each...
One of two things:
Either:
a) The STK chips you put in are no good (not uncommon)
or
If you weren't careful you may have removed a surface mount resistor accidently while desoldering the orignal STKs. I had a customer do that to me once and figured it out by comparing the board to the schematic for that board location.
1helpful
How do I fix a converence problem?
Hi.
First try using Autofocus. If there is a convergence problem this won't fix the problem.
Try using the convergence alignment procedure from service manual.
Here the procedure that works on most Hitachi rear projection.
Here the grid with convergence problem
If the procedure does not work, then the two STK392-110 on convergence board must be replaced.
Before replacing the ICs you can test the pico fuses located on convergence boards. Simply read ohms to test if they have continuity.
Better also testing components on convergence board like resistors located at the base of STKs.
After removing the old STK, the new ones must be re-soldered using cooling paste.
Price for single IC can is about $8/$20. I think
STK392-110 on this model can be better replaced with STK392-150. I suggest contacting the seller on this.
The service manual is available here.
I suddenly have color separation (blue, yellow,white). Flash focus won't work. Any suggestions.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note: there are also pico fuses (on the same convergence board) that need to be checked/replaced
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
3helpful
Sony KP -46WT510 Convergence Problem
Yes - If you are failry handy and take your time its a DIY project.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Convergence issue with kp-57ws500
You have to remove one leg of each pico fuse to test them properly. Same goes for the resistors. Other options is you have a bad soldering joint or a faulty STK chip still.
1helpful
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
1helpful
2answers
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
