Question about Roxio Easy Media Creator 9 Suite (227100) Full Version for PC
I tried to reinstall roxio creator 9, but am getting a cd key code error. I have checked time and zone, as well as, removing all directories, subdirectories of Roxio, and clean up the registry, but still getting the same error. Is there another key or program that keep records that needs to be removed before I can reload creator 9?. I use the same disk on another computer and install it correctly, to see if it works, it did. GL
Posted by bonchance on
  • bonchance Feb 19, 2011
    I did remove creator 9 before my attent to reload, that's when I gor the cd key code error. Order of sequence: Remove creator 9 using the uninstall program, then tried to reinstall, then I got the cd key code error. I read to remove all directories associated with creator 9 and Sonic, then clean up the registry, which I did as directed. I even checked the time and time zone. After doing all that, I still get the cd key code error (I carefully typed and verify before I press the ok button.
Anonymous
  • 197 Answers
You may need to remove the first program first then reload & set up
Posted on Feb 19, 2011
2answers
Well I am still looking for a answer to why the invalid key code has become invalid. What I would like to know how to get the key code to valid so I can reinstall Roxio easy Media Creator suite 9 back in...
invalid codes are not common but they do exist you will need to contact roxio inc at www.roxio.com tell them the problem supply the error install id number and they said they would be happy to supply you with a new code
merry christmas
please take the time to rank this advice below
I am trying to reinstall Roxio East Media Creator 9 Suite. I wrote the key code directly on the disk, and now I can't read all of the numbers/letters. here is what I have so farL L8-QXPDP-( )C5Q6 -...
Hi, well if you cannot use your existing one, why not simply make your own, if you go to this download site below you will be able to download a thing called a Key Generator: this then will generate a valid key for you that you can then use to activate it.
http://torrentz.eu/13b7eed59f868cdd64ae80c2ee178245e8ffb369
Also if you search through your registry you may be able to recover your serial number in plain text.
http://www.9down.com/Roxio-Easy-Media-Creator-9-Suite-7857/
At the above site you can download a new copy with serial etc. Just think outside the box....
7helpful
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
I tried downloading the Roxio free program. It
Find the program under Programs directory, right click the directory icon, and select delete.. this will remove it.. to find it right click on icon on desktop, or start menu, and choose "open file location" or look in the properties box for the path.. anyway go there and delete it. be careful you get the right one..
2helpful
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Lost product key code
i have roxio in my pc,  when i click the icon, i get a message saying your last command could not be completed, an unknown error.
how to solve this problem
please help me
[email protected]
Lost cd key code for roxio easy cd creator 5
keygenguru.com will have almost any key you want
2answers
[email protected]
u already paid for the software so dont use any pirated key .. just goto roxios website http://www.roxio.com/redirectmyaccount
Failure to open cd
Hi Install - CDBurnerXP Pro 3.0.116 Download from here: http://www.cdburnerxp.se/download.php Good Luck
Roxio Easy Media Creator 9 Suite (227100) Full Version for PC Logo
Top Roxio Computers & Internet Experts
Randy Prevost
Randy Prevost
Jim Fernbank
Jim Fernbank
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
