Question about Danby DWC283BLS Wine Cooler
Code E4 on dandy wine cooler mod # dwc283bls - Danby DWC283BLS Wine Cooler
Posted by paul94568 on
Michel Bourduas
    New Friend:
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Posted on Mar 04, 2011
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
I have a e4 code on my wine cooler
I am sorry to hear regarding the trouble. This is a common problem on this unit. E4 refers to a faulty control board failure. Unplug the unit for few minutes, say 15 minutes and then turn it on. If this would not reset the error code, the only solution is to replace the board.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Danby DWC283BLS Wine Cooler
Looking for the mother board for the DWC283BLS Wine Cooler
go at sears go to this address http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
and good luck with the repair
May 15, 2011 | Danby DWC283BLS Wine Cooler
My Danby winecooler, the bottom part, white wine part, says "E3" and does not work. That is only after I unplugged it and started it again. Before that it went down to 32 degrees and froze a...
good morning. according to mark rydal the director of dandy inc (publish ny times 22sept 208) there were faulty compressor electrodes fitted to the 283-3400 series yet there is no advice on the fix as a tech i beleve the cause is faulty sensors in the pcb but to date all the paper work i can find on these problems has the owners binning them after having them repaired as the fault re occurs over and over
hope this helps
merry christmas
Dec 24, 2010 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
E4 message
Disconnect the power cord from the wall outlet and wait 30 minutes before pluging back in. This should clear all settings on the cooler.
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS.pdf
Aug 07, 2009 | Danby DWC283BLS Wine Cooler
E4 Code
Dear moriquenda
welcome to fixya.
Did you try resetting the system by pulling the plug and waiting 5 minutes then restarting the wine cooler?This may solve you problem.
Danby expects customers to call service and does not imagine the rest of the world being able to utilize these codes.
Closed minded, Huh?
Please remember to leave a rating!
Huuum
Sep 28, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
975 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
Marvin
Marvin
Are you a Danby Furniture Expert? Answer questions, earn points and help others
