Garden Logo
A
Anonymous Posted on Feb 18, 2011
Poor gas in carb it starts and runs for a few seconds and then quits
Andrew White
Level 3:
  • Master 2,239 Answers
  • Posted on Feb 18, 2011
Andrew White
Master
Level 3:
Answers
2239
Questions
Helped
909827
Points
5950
If the saw has a primer bulb keep pressing this, the bulb will pull fuel from the barb and dump back into the tank, now drain the tank and start again.
Toro CCR 2450 snowblower won't start.
Try a short burst of starter fluid into the carburetor and promptly pull starter. If it runs for a couple seconds and quits then the carburetor is not delivering fuel.
If it doesnt run on starter fluid then either flooded, insufficient spark, or poor compression / crankcase leak.
Oct 26, 2019 • Toro Garden
1helpful
Engine won't stay running - only will start with starting fluid.
VERY COMMON problem with gas engines.
I recommend starting all your gasoline using machine ever month or two. Let them run a few minutes. Same with cars/trucks.
Start you r car/truck every couple months and drive forward and backward several feet as well.
If you have a gas shutoff valve, turn it off and run engine till all gas is out of carb before storing.
Gas turns to a hard lacquer is sitting too long. remove air cleaner covers, Pour some real good (strong/thorough) carb cleaner in carb and leave sit over nite. If that doesn't work, do it another nite. If not working yet, you may have to take carb off and open it up. Be careful there are little tiny parts in there.
Apr 03, 2016 • Garden
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 • Garden
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
1helpful
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
1helpful
Mac 110 only starts when gas is poured into carb . runs a few seconds and quits.
Sounds to me like you have a plugged fuel line.You need to dump the gas out,then disconnect fuel line,and blow air through it.
Honda GX160 5.5 horse power The engine won't start . It almost starts for a second and quits. When I took off the air filter and put a few drops of gas in , it started for about 10 seconds than quits .I...
make sure you are getting fuel to the carb and make sure the float and seat in the bowl move freely and all is clean and clear. this sounds very much like a fuel issue,, also - while you have the bowl off the carb -make sure you spray carb cleaner into the jet and seat area.
if you are still having problems --please feel free to write me back here and I will do my best to walk you through the repair steps.
c...
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
1helpful
2answers
2answers
Quit running while driving. Will start but only idles for a few seconds
You'll have to adjust the Idle so that the car will not quit running while driving .because less gas is entering to the engine.after you adjust the Idle then the car can run and not quitting.
Top Garden Experts
Jay Finke
Jay Finke
john h
