Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi tools I already have at least?
kocojim
    New Friend:
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Posted on Aug 20, 2012
Anonymous
    New Friend:
Yes, P103 will work with any 18V Ryobi tool
Posted on Feb 22, 2011
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Is there a difference between the ryobi p103 lithium battery and the ryobi p106 lithium battery?
p103 is name of the battery. p106 is the kit with 2 p103 batteries. same thing just 2 times. the p104 however is bigger and holds more juice.
Jun 15, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Dec 27, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on...
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
Apr 10, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I leave my Ryobi P113 charger with a P103 battery inserted in it for an indefinite amount of time with the charger plugged in, without doing damage to the battery or charger? Thank you. Phil
Yes you can that is an automatic charger when it is fully charged it shuts down the charging portion but keeps the charged light lit however this does not effect the battery.
Aug 13, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
1,694 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
