Ovens Logo
Posted on Feb 18, 2011
Hi I have a samet oven and the plates work but the oven stoped working. Does it have fuses someware... Leon
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
814
Points
6
I have the exact same problem, and we also cant find the fuses??
siegfriedpre
Level 1:
  • Posted on Dec 23, 2012
siegfriedpre
Contributor
Level 1:
Answers
Questions
0
Helped
814
Points
0
It is most frustrating - same problem.
It is a thermal protection switch wich is supposedly activated when the oven is nor properly ventilated. Mine has been installed as per instructions from the supplier - but still. I have bypassed this cut-off device. Oven is working perfectly now.
Samet oven model N99VIX not heating the bottom part, what might be the problem? Can I get it's manual
You need a new heating element. Check it for continuity with a digital multimeter.
https://www.google.com/search?q=Samet+oven+model+N99VIX
No manual, they appear to be a kitchen cabinet manufacturer
https://www.google.com/search?q=Samet+N99VIX+manual
Jan 02, 2024 • Ovens
How do you switch on a samet oven model N99VIX
I find it strange that this make and model does not exist.
Samet N641. Is it self-cleaning?
spray on oven cleaner has always worked for us
May 05, 2020 • Ovens
Hi the hot plates have stopped working on my fisher and paykel oven
there is a seperae fuse for the elements if it is wired as a two phase which mean at your fuse box there is teo oven fuses one of them is blown or tripped
Bosch oven not working
Is it electric or gas?
If that is electric then check your fuse board
if it is gas check to see if you have ran out of gas
lease might seem simple but sometimes we forget to check them
Feb 15, 2012 • Bosch Ovens
Hi i have an Electrolux eou63102x double oven but the fan has stoped working in the bottom oven can you tell me the most commen part that may need replacing
You really need to establish if the fan is getting a supply to it, if it is, and it is not working, then you need to fit a new fan motor.
If no power to it, then could be a faulty switch, or break in the wiring, a bad connection.or an internal fuse that has gone.
Hope this helps.
1helpful
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 • GE Ovens
37helpful
3answers
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 • Ovens
Top Ovens Experts
john h
Are you an Oven Expert? Answer questions, earn points and help others
