Question about KitchenAid Dishwashers
Child proof lock is on and dont know how to turn it off?
Posted by axelsens on
Anonymous
    Guru:
  • 500 Answers
Child Lock is activated. Look for a picture of a small child's face on the Facial Panel (usually with picture of a lock) follow the arrows to 2 buttons, press and hold these buttons for 5 - 7 seconds. Child Lock will then deactivate.
Hope this helps
* If you found this solution helpful, please vote positively.
Posted on Feb 18, 2011
2 Related Answers
jumptrout51
steve
  • 3361 Answers
SOURCE: child proof lock is on and dishwasher will not
HOLD down the AIR DRY button for 4 seconds.
Posted on Jun 14, 2009
Anonymous
  • 8197 Answers
SOURCE: child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Posted on Apr 18, 2010
1helpful
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
I have a high pointe microwave that the child lock comes on after two minutes. You can clear the lock but after two minutes the lock hoes back on. How can I clear this permanent ly . Please let me know
Please revert back with the Modal # so that I can provide you modal specific information.
However, you may try this generic troubleshooting and check if that helps. To cancel the child proof lock: Press CANCEL button for 3 seconds, then a beep will sound and the
indicator light will turn off.
2answers
Turn off child lock
Can you identify the model of the oven you need help with or anything like that? Not all child locks on ovens are configured to function or be utilized the same way.
Sep 22, 2013 • Ovens
My dad put the child proof lock on and now the rear door wont open at all help 2009 f 150
You will have to take door panel loose to open door & fix the rods inside the door .call me if you need help 8174570887
My back doors wont open
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
How do i turn off the child locks on the back seat doors?
When you open the door, on the back edge of the door there should be a switch that you can move to disable/activate the child proof locks.
Rinnai 431 heater. Power button will not turn unti on. Unit is pluggen in, the child lock will engage and disengage. No other lights (temp lights etc) are on. Checked all connections on circuit board and...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
" If Child Proof Lock is activated during normal operation, then no functions other than the On/Off switch will be operable until the lock is released"
"If Child Proof Lock is activated while the appliance is OFF, then the complete range of functions will be locked"
6helpful
Child proof lock light is on, cannot run the dishwasher
light turns off.
Child proof lock stuck on
hi! can you please specify the brand and the model of you television.
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
