RCA F27442 27" TV Logo
Posted on Feb 18, 2011
I have an RCA F27442 TV without G-link cables and need to select cable tv channel input. The setup routine will not allow selecting cable channel input unless I first set up G-link. Is there any other way to set TV to receive more than 13 channels so I can use on my cable system?
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3205
Points
34
Yes, enter the menu. Look for signal source (ant/cable) select cable. Then run channel scan. This is an older TV and will require some time for the system to scan the cable channels and adjust. The process could take up to 20 min. Do not disrupt. Wait fo unit the TV is completed the process. If you have the operations manuel, the step by step for this process is posted.
Please note this TV is only capable of process NTSC TV signals. If the cable company you are using is supply Digital or Quam or ATSC type signals then the TV just won't work.
G-link can be turned off through the menu. You should see that selection in the first or second page of the set up menu. G-link is for TV guide and record setup for VCR operation. The TV guide should also be set to off or "no" in the same setup menu. You MUST got through the complete setup menu in order for the TV Guide not to try to operate each time you turn on the TV.
Testimonial: "perfect solution THANKS!"
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
No remote
Try the buttons on the side of the tv. You should be able to get to the setup menu with them. Just select CABLE as the source for the tuner.If that is too much of a problem then you might try connecting the cable box to the tv using RCA type cables then just use the buttons to select the new input number.
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
1helpful
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
I can not program the tv with the cable, which input goes with the cable channel. I have a 32 inch RCA with SRS . HELP
I do not see a question. "Which input goes with the cable channel?" Don't understand. Is there a cable box or SAT box connected to the TV? What kind of cable is running to the TV from the source? If you just have the coax cable going from the wall to the TV, then you need to auto format the channels. Select menu on the TV remote. Find Sources or Cable. Select "Cable" not "Air". Select Auto Format. May take several minutes. Input selector from TV remote should be "TV".
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
3helpful
2answers
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
5helpful
3answers
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
