Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player 2. Switch the TV to the input for the DVD player 3. Remove any disc from the player 4. Press the SETUP key on the Zenith remote to open the on-screen menu 5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote. 6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again 9. Use the down arrow to highlight the PADLOCK for the parental control settings 10. Press the RIGHT arrow once to enter the parental control menu 11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER 13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Hi, Make sure that your vga or graphics driver are properly installed and not corrupted. And you can also try downloading another video player like VLC player. Try this link: http://www.videolan.org/vlc/ Thanx
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
The problem that you are facing is an issue with yahoo email it self.
If you have upgraded you yahoo email to higher version then i would suggest you to lower down the version. That will solve the problem.
the driver system may have got faulty.. if you know how to open the player open it and see what is stopping it from opening. else take it to some tech. he will do it for u
