There are several fans on your unit one on the top with the compressors, one inside the freezer, and one at the bottom. If you open the freezer and the noise gets louder or stops then you know it is the evaperater fan. Sometimes the bearings start to go and they make louder noise. Also check on the back wall for frost you could have a frosting problem and the fan blade is hitting on the ice
SOURCE: viking freezer and fridge power on but not getting cold.
Are you sure the compressors are running, it could just be that the fans are starting but the compressor does not start.
It sounds as though you may have fried the boards again.
Remove the top grille and reach in to the compressor, to see if it is running, you should be able to feel it vibrating, there should also be some heat to it, not neccessarily hot.
have you tried putting surge protectors on the outlets, to save the boards in the future?
