WASHER SPINS AND AGITATES AT SAME TIME:
( Belt drive) I SUSPECT YOU HAVE A BAD TRANSMISSION SPRING ITS NOT THAT EXPENSIVE OR DIFFICULT TO FIX. YOU CAN INSPECT IT BY TURNING MACHINE ON ITS SIDE AND LOOKING AT THE TRANSMISSION SPINDLE, SHOULD BE LOCATED UNDER THE PULLEY WHEELS AND MOTOR ( ON BELT DRIVE MODELS). U WILL NOTICE A SPRING ABOUT 2-3 INCHES LONG GOING AROUND THE SPINDLE IT SHOULD ALL BE ONE PIECE IF IYTS BROKEN OR CRACKED ETC IT NEEDS REPLACING. -
Another thing to Check is the wig/wag solenoid also in some models. The cam shaft may have slid and broken away from wig wag solenoid
( Direct drive) a simple way of determining with spin or agitate problem is with your washer's transmission (also called a gearcase) or some other part like a clutch or a drive motor coupler. And usually the problem is in the transmission itself in direct drive models. When it comes to spin and agitate at same time.
your next step is to
remove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem is
not in the gearcase- look for trouble in the
clutch(see the "Clutch" section below),
basket driveor the
tub drive block(see the "Drive Block" section below).
If, on the other hand, the disc is NOT spinning, check for a problem with
the motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. BTW, replacing the motor coupler is probably the single most common repair on this washer.
Read more:
Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
