I just replace the Maxtor HDD on my Sony RDR-HX900 with a 160 GB Western Digital IDE drive. When I went into the "service mode" screen (by holding down the record pause, system menu and tools buttons on the front of the unit) and attempted to format the HDD I received the following message: "ATA Initialization...ERROR". I did the self-diagnostic checks and there doesn't seem to be any circuitry problems with the unit.
Check to see if the BIOS has ATA, SATA, Legacy setting for the HDD. Try all settings for the HDD. You'll need to have your OS CD/DVD in the optical drive as well so you can begin installation fo the OS.
If that doesn't work, Sony's tech support is pretty good if you can get them to talk to you. I've had issues w/ out of warranty laptops and PCs in the past.
Good luck.
SOURCE: replace faulty HDD of Sony RDR-HX725(HDD ERROR).
I have the same problem, but no solution for me. Have you fix the problem? Could you use the remote successfully?
Thx
SOURCE: Failed Sony RDR-HX900 hard drive. Replacing with new HD?
You need to get an RDR-HX900 service manual either from sony or from a supplier advertising on the internet. Service manuals typically have step-by-step instructions on replacing individual components
SOURCE: Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
SOURCE: Sony rdr-vx525 video cassette/dvd recorder.
Yeah, its a pain in the ****. The instructions to fix are here: http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
SOURCE: Suddenly my Sony RDR-VX525 will only record in
Please clean your lens with lens cleaner. Replace the lens if needed.
If still problem , please repair the circuit board.
Regards
