JVC HD-52G886 52" Rear Projection HDTV Logo
A
Anonymous Posted on Feb 18, 2011
Have a jvc hd rear proj, m#hd52g886 new lamp light on front keep flashing and no picture...Help
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Feb 18, 2011
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340437
Points
4062
Seagoblin28,
If you haven't replaced the lamp you should. If you have replaced the lamp you may just need to reset the unit. Go to my tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains where to get the lamp at the best price and how to replace it as well as links to additional problems.
Thanks for using Fix Ya and for the great rating.]
hardrocko
Picture adjustment for JVC HD52G886
Here is the manual http://www.retrevo.com/support/JVC-HD-52G886-TVs-manual/id/279ci059/t/2/, also may need to go into picture advance settings to do some calibrations.
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
My hd52g886 has intermitten picture with sound
when the picture is out see if you can see the lamp light on in the back inside the tv. if its still on you might have a problem with the optical engine. if not try replacing the lamp part# tscl110u
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
2helpful
2helpful
2answers
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
4helpful
3answers
Jvc hd -61z456
These guys are correct, you need a new dlp lamp. The lamp # for your particular television model is the TS CL110UAA.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
