Dell Dimension 4600C PC Desktop Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i do a compete system restor on my computer?
Brian Sullivan
Level 3:
  • Dell Master 27,725 Answers
  • Posted on Feb 17, 2011
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5670182
Points
79191
If your computer has a system restore capability you might be able to restore it to a date when you had these phone no. on your computer (this may vary depending on your operating system)
click start all programs accessories scroll to system tools open you should see a system restore open this up click next then select a previous date to restore your computer to
hope this helps
2answers
HP System Software Manager
The HP Remote Support Software Manager is an application installed on HP desktops and laptops, that enables Remote Assistance on the computer for HP personnel access. This Remote Support client allows a technical support representative from HP to see and control your computer to assist you with making changes on the machine. The HP Remote Support Software Manager may be safely uninstalled from the computer. Uninstalling this application will not affect any other functions and features. However, you should create a Restore Point prior to uninstalling any software just in case problems arise with the changes. Create Restore Point in System Restore Click the Windows "Start" button and then right-click on the "Computer" entry. Click "Properties" from the context menu. Click the "System Protection" link in the left navigation pane. Click the tab labeled "System Protection" and then click the "Create" button. The Create button label indicates that this action will create a System Restore Point now. Type a description for the manually created Restore Point and click "Create." The System Restore Point is manually created. Uninstall HP Remote Support Software Manager Click the Windows "Start" button and select "Control Panel." Click the "Programs" link in the Control Panel. Click "Programs and Features." The list of installed programs will appear. Locate the HP Remote Support Software Manager in the list and click the entry. Click the "Uninstall" button on the top navigation bar. Type the "Administrator" password, if prompted, and click "Continue." The program is uninstalled from the computer and the entry disappears from the Programs list.
tip
WINDOWS XP SYSTEM RESTORE
System Restore is a tool that takes your computer back to a previously working state. This option is available in Windows ME, Windows XP and Windows Vista. Windows takes snapshots of critical system files, program files and registry settings and stores them as "Restore Points". If ever you should have any problem with your computer, you can "restore" your computer to one of these Restore Points, when your computer was working fine.
Please remember - System restore does NOT have any effect on your personal files such as emails, documents or photographs.
HOW TO USE SYSTEM RESTORE TO RESTORE WINDOWS XP TO A PREVIOUSLY WORKING STATE
In order to perform a System Restore, you must have administrative rights in your computer. If this is your own personal computer, then chances are that you will be having administrative rights in it, however if you are on a network computer, say for example in a computer at your workplace, then you will have to request your Network Administrator to help you.
In order to restore Windows to a previously working "Restore Point" follow the steps given below:
1. Log on to Windows with administrative rights.
2. Click Start, go to All Programs, go to Accessories, go to System Tools, and then click System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system restore point and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6. Log on back to your computer. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you have successfully restored your computer to a previous state, and the computer is performing as it should be, you can stop here.
But if the restore process completed successfully and the computer is still not performing as you want, you can either restore your computer to a different restore point or just undo the current System Restore. In order to undo a System Restore, please continue reading.
HOW TO RUN SYSTEM RESTORE FROM THE COMMAND PROMPT?
Many times, you may not be able to run System Restore because your computer will not start up normally. But you can still run System Restore from the command prompt.
  • Click on Start -> Run -> and type in %systemrestore%\system32\restore\rstrui.exe and click OK
OR
  1. Start up the computer in Safe Mode or Safe Mode with Command Prompt
  2. At the Command Prompt type %systemrestore%\system32\restore\rstrui.exe
  3. You can replace %systemrestore% with C:\Windows, if you like
  4. You might have to select the Operating System in your computer
  5. You might also have to enter your username and password
  6. You should have Administrator Rights in your computer to do this.
HOW TO UNDO A SYSTEM RESTORE:
You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
5. Logon to the computer as Administrator. The System Restore Undo Complete page appears.
6. Click OK.
You can now run System Restore again from a Different Restore Point.
on Jul 06, 2010 • Computers & Internet
Hello Sir,i am having Hp-compaq 8100 elite competable mini tower,Model:XYS173S-A2N,I INSTALL WINDOWS-7 PROFESSIONAL 64BIT,WHEN I AM RESTARTING WINDOWS DISPLAY IS NOT COMING,SO WHAT SHOULD I DO.PLZ GIVE ME...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
2answers
Following a System Restore on my Dell Inspiron it has come up with windowsroot system 32 ntoskrnl. The computer was not supplied with the full Window's XP home edition CD, just a Dell reinstallation CD...
If you get that message every time you run system restore, that restore point is no longer any good. You need to try a different restore point on a different date. System restore is NOT meant to be a backup. You need to be running a backup of your computer if you don't want to lose your data. Hopefully you will have another restore point, possibly earlier than the one you used, which is good. If you need to reinstall windows, you will need to get a disk. You can send me a message if you need one.
My daughter mess her netbook up need to be restore to oringnal setting but how do i do this
Restore the computer:
To use System Restore follow these steps:
1. Log on to Windows as Administrator.
2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Have xp professional and on my start up page all my links are gone? cant even do system restore.how do you restore it or fix this problem, really need some help!!! also get c:\program...
How to use System Restore to restore Windows XP to a previous state loadTOCNode(2, 'moreinformation'); Note To perform System Restore, you must be logged on to Windows as an administrator. If this is your personal computer, you are likely already logged on with an administrator account. If this is a computer that is part of a network at work, you might have to ask the system administrator for help. To verify that you are logged on to Windows with a user account that is a computer administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin) To use System Restore to restore Windows XP to a previous state, follow these steps:
  7. Click OK.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section.
2answers
Need to restore computer
if you want restore your computer then just flow the step
1 start
2 all programs
3 accessories
4 systems tools
5 restore systems
after that folow the screen your will able to restore your systems
How do get to the restore options? f key? ibm m 8147-23u desktop
Dear Sir,
plz use this step for restore
  7. Click OK.
How do I restore my program for santa cruise? i have no sound.
Dear sir,
  7. Click OK.
2answers
Need to restore computer **** dont have a cd is there any other way
Follow below instructions......
  7. Click OK.
thank you.......
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
