Question about Yamaha HTR-6130 Receiver
I have a yamaha htr 6130 receiver and it has different sound levels for all of the speakers. is there a way to fix the gain on each one?
Posted by jpdub45 on
David Dunn
    Brigadier General:
  • 8,546 Answers
Yeah, set it up according to the manual...
Page 23
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
Posted on Feb 18, 2011
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
Receiver displays Dolby Digital while watching TV, but only 2 front speakers work. This is the case on only certain TV stations. I have a Yamaha HTR-6130
Depending upon transmmission bit rate, if the transmission is > then 6130 bit rate it will automatically change to 'STRAIGHT' mode and in this mode only two front speaker will work.
Oct 15, 2009 | Yamaha HTR-6130 Receiver
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha HTR-6130 connected to a Samsung 550 plasma tv. I find the speaking sound in movies and tv programing to be too low relative to other background sounds. Any way to raise the relative...
If your running the receiver in 5.1 using a center channel, go into the main menu of the receiver and select "speaker settings" toggle to "center channel" and adjust the gain to taste. If you need more help, post a comment and I can help you some more
Jun 25, 2009 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
290 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
