Question about DeLonghi DDE50E Dehumidifier
My DD50E has stopped collecting water and filling up. It runs but doesn't collect water.
Posted by ameliasolwri on
D. Floyd Kolb
  • DeLonghi Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Mar 30, 2011
4-5 years old. Has work great all that time. In the past week it stop collecting water. It runs but never any water in it. It's not leaking out. The collection pail is dry as a bone.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 23, 2011 | Amana D530M Dehumidifier
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
Dehumidifier does not collect moisture. cleaned the filter and still doesn't work. fan works fine.
heatman101
Jun 22, 2011 | Kenmore Dehumidifiers
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
My dehumidifier runs, but doesn't collect water...then shuts off
heatman101
Jun 06, 2011 | Kenmore Dehumidifiers
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
Two years old Delonghi DE400 doesn't collect water, everything looks fine and running (no water but smell in basement).
heatman101
May 10, 2011 | DeLonghi DE400 Dehumidifier
Collects very little water never fills up the container. all fiters are clean
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 11, 2010 | Fedders A7DH45B2A Dehumidifier
Runs, stops collecting water.
check defrost cycle and give me thumbs up
Aug 08, 2009 | Dehumidifiers
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
DeLonghi DDE50E Dehumidifier Logo
1,259 people viewed this question
Top DeLonghi Dehumidifiers Experts
jdthefixer
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
