SENAO NL2611CB3 PLUS (NL2611CB3PLUSDX) 80211b Wireless Access Point Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The bridge locks onto the strongest signal automatically. this is not the network i want to connect to. how can i select the desired access point for the unit to communicate with?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557234
Points
31058
Use "change order of preferred networks" to lower the priority of the "not-wanted" network, to a level below the priority of the "desired" network.
How do I obtain a password for a wifi connection between a ipad. All networks available are locked
Presumably, you have a router which provides wireless access for your iPad. (if this is not the case, you are going to need this).
You will need to get the name & passcode (or the key) for your wireless security. Simply connect to your access point and input your key, then you should be good to go.
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
HOW DO YOU GET ON LINE WITH A PSP
Step1 – Go to Settings and then select Network settings
Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
In a nutshell there we are, 7 simple steps to connect your PSP to the internet using a wireless router to enable you to start surfing the internet, playing games online with friends, exchanging pictures and downloading your favourite RSS channels.
2helpful
I can't get the internet for my psp
FOLLOW THESE 7 STEPS
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point2_bing.gif is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings2_bing.gif will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
1helpful
How do I get wifi on my psp
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
2answers
Cannot connect to wireless network
Check the key carefully.
Also check your config carefully
1helpful
How do i get on the internet with my psp
Ok First you have to make sure that you are in a WiFi (Hotspot) area because that is how the psp gets online.
  1. Step1 – Go to Settings and then select Network settings
  2. Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
  3. Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
  4. Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
  5. Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
  6. Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
  7. Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Top SENAO Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a SENAO Computer and Internet Expert? Answer questions, earn points and help others
