<p>He the volume of the iPod Touch can be affected in some way,
the definition of musical sound check the volume limit set in the settings
device preferences. The tool of sound check, which can also be found on iTunes,
check your iTouch music and video library for the stabilization of the
equalizer song for a constant level, the volume limit reduces the volume to
grow beyond a set point, which helps the potential adverse effects of hearing
loss caused by loud music. <br />
<p><br />
<p>1. Press the button to the left of the iPod Touch. The
volume switch top left of the iPod Touch increases the sound volume, and gives
a volume icon on the screen as it grows. Accident on the volume button for the
iTouch, it seemed sound problems. Touch the "Music" icon to start
playing the song, press the volume for music to grow. <br />
<p><br />
<p>2. Adjust the volume control settings. Tap Settings on the
iPod screen Touch, Touch "Music" and tap "volume limit."
Slide the tab to the right of way to reduce the volume bar to change the limit
of the maximum. Press the Home button to save and Settings. <br />
<p><br />
<p>3. Sound Check off. Tap "Music" in the Settings
window and slide the guide Sound Check to the left to the sound check feature
off. A Sound check song keeps playing very hard at the same level. While the
function prevents sudden jumps in volume, can also lead to a series of songs to
play very soft, depending on the quality of the music. <br />
<p><br />
<p>4. Adjust the volume to your headphones. Press the
"+" button on your Apple headphones, the volume of a music or video
playback to increase. If a song or video does not play, the volume control
adjusts the volume on the iTouch. <br />
Distorted sound on a MP3 player is usually caused by one of the following:
- Volume is set on to high
- Battery is going flat or does not hold enough chargeL: test by playing song while connected to an external PC power source/USB charger.
- Your Earphones/Headset has been damaged due to abuse (player songs too loud in general for an extended period) or too loud from another/PC source) - To test, try it on another music player or PC.
- Your unit is really faulty or you have a bad plug connection: to test, try jiggling the plug while listening to a song.
So you are here to know which is the best brand in market available. If you are games geek and require clarity then go for Sony Ericson. If you are fond of loud music go for Nokia. If you are fond of soft melodious songs then again Sony Ericson. Choose whatever suits best to your requirement.
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
