Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
My water isnt draining after the cycle is completed.
Posted by Patricia Mikolas on
Kevin White
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Feb 17, 2011
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
2answers
Draining after completion of cycle
Miele dishwashers are typical not to drain all of the water. It is the way the siphoning system is designed. You will always have a bit of standing water after cycle completion but should not be above the bottom filter. You can manually drain the dishwasher by selecting any cycle and letting it run for 30 seconds and then turn the dishwasher off. Hope this helps
Sep 14, 2009 • Dishwashers
2helpful
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 • Dishwashers
3helpful
2answers
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Error code "nd"
ND = No Drain error.
If the unit is not pumping out the water then I would not thin twice about changing the pump. You can test the wires going to it for voltage when the unit should be in the pump out cycle.
If there is voltage to the pump then it is shot.
If there isnt any voltage going to it then the controller board is likely failed and needs replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
