Question about Belkin (F5D7231-4) Wireless Router
How do you set a pass word for my wireless? - Belkin (F5D7231-4) Wireless Router
Posted by ieltayeb on
  • Belkin Master
  • 7,733 Answers
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
To get in to the configuration pages, you need to be connected to your router. This can either be with the Network cable, or via your wireless adapter. Start up your browser, and enter the address for your router. These differ, but for the Linksys router it will be:http://192.168.1.1
You will then be asked for a username and password. Routers will have a default for both of these. For the Linksys, it's admin for the username and admin for the password. (Look in your manual for the router's address and default username and password.) Click OK and you'll be in to your configuration pages.If you can't see any configuration pages then the connection from your computer to the router is not working. So don't blame your ISP! Time to pour over those manuals! Another thing you may need to do in the config pages is to set up wireless security. If you don't have security switched on, anyone within range of your wireless router will be able to connect to it. There are two forms of security that most wireless routers use, WEP and WPA. What you are doing here is encrypting your signals with a key. With wireless security turned on, the router needs your key before it will allow any traffic through it. No key means no access.
WEP
Wired Equivalent Privacy. This is an older form of security and is not as safe as WPA. There are programs around that hackers can download to crack WEP. Once they have WEP cracking software, they may be able to gain access to your router and get a free ride on the Internet At the very least!
The WEP key, though, will be either 64 bits or 128 bits in length. (128 bits is 26 characters, and will be mixture of the numbers 0 to 9 and the letters A to F.) If you have a Livebox from Orange, for example, then it comes with WEP security. When setting up the router for a wireless connection, you have type out all 26 characters. Get one wrong and it won't connect!
WPA
Wi-Fi Protected Access. WPA security is really an update to WEP. It uses different and stronger encryption, and so is harder to crack. It's easier for you to set up, as well, because you just need to set up a short pass phrase instead of typing out 26 letters and numbers! You should use WPA and not WEPA lot of wireless routers don't have security turned on by default. Your configuration pages will allow you to turn it on, and there is usually a help menu which explain the various security settings.
Posted on Feb 17, 2011
Setting a password to my wireless router
just click on your wireless setting at the bottom right of your computer it might be under hidden click on to your wireless settings in there it says set your security pass word put a pass word in and remember it and thats it
Dec 13, 2011 | Linksys Wireless-G WRT54G Router
May i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
you need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
I am using time warner cable high speed internet. and trying to connect my ps3 through a belkin router but it is not working. the wireless icon pops up from the router but what is a WPA Key??? HELP!!!
WPA === Wireless Protected Access
It's a level of encryption between the router and each wireless device, to add "security" to your wireless traffic.
Use an Ethernet cable to connect the network-port on a computer to one of the LAN ports on the router.
Restart the computer.
Start Internet Explorer, and connect to the web-server "inside" the router.
From this web-interface, you can set an SSID and set the encryption-level (e.g., WPA) and you can set a password/pass-phrase/pass-key for your wireless network.
Use the same SSID and password on your PS3.
Aug 29, 2010 | Computers & Internet
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Find pass key for our lap top for the family network.
Log into your router's web interface, if possible through a computer connected to the router by cable, by starting an internet browser and navigatng to its maintenance IP address, usually set by many manufacturers to 192.168.0.1 or 192.168.1.1. An authentication request will come up. As you haven't speciffied your router model, there are routers whose both user name and password fields are set to 'admin'. Other routers use 'admin' as user name only, requiring the password field to be left empty. Once you get into the router's web interface, go to the wireless settings, and change the wireless passphrase to a new one of your choice. Make sure to change the other devices, which use to connect to the router, to the same new passphrase.
If you need further details, please, provide your router model and manufacturer.
Hope you are able to sort your problems out.
Regards, Carlos
May 22, 2010 | Computers & Internet
Don't know my pass phrase (Key) to wireless connection
type 192.168.1.254 at the address bar on ur browser
and should ask you for a username and password username will remain (blank) ant the password will be (admin) = default by linksys
go to wireless settings
set up a WEP not a WAP
and if its set up it will tell you what it is
if you have to make it well make it and you´ll know it
rate me please , july
Apr 20, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Laptop connection problems to wireless router after reformat
Hi Drew,
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Apr 03, 2009 | Linksys Wireless-G Broadband Router
Need to retrieve pass word
If you have a new router, try accessing your router configuration page and set a new wireless network name and a new wireless password.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Have forgotten my pass code foe my netgear wireless router
there will be a button at the back usually that you can press in for about 10 seconds.
this will restore the router back to factory settings.
Dec 24, 2008 | NetGear WGR614 Wireless Router
Belkin (F5D7231-4) Wireless Router Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
