SOURCE: Different WIndows operating systems on two hard drives
1) Try if Cable Select will work for you, meaning that the existing HDD will be Master, and the Quantum will be Slave. If there are problems in identifying the drives by BIOS, manually set the existing one to Master, and the Quantum to Slave.
2) You don't have to install anything on the second drive. The operating system has to be installed on the primary drive, from which the system boots.
3) If the Quantum drive does not contain anything useful, it would be advisable to go to Management Tools, Disk Management and delete the partition from it, re-create it, and format as NTFS - under WinMe it was surely formatted as FAT32, which has a file size limit of 2GB and doesn't let you set any access permissions.
If you don't need NTFS, then at least re-formatting the drive would be advisable, as it's the simplest way to get a clean drive, without unwanted stuff (like WInMe, programs installed on it etc.) and no data fragmentation, that occurs with time and slows down the drive operation.
4) You might need to go to Disk Management anyway to assign a drive letter to your newly attached drive - most probably your existing drive is C, your CD/DVD is D, so you'll have to assign letter E to it, or better yet, some letter further in the alphabet, like Q for example - especially if you use external disk devices, like flash pendrives etc., which already were assigned the letter E when you used them.
5) With the harddrives so cheap nowadays, does it really make sense to use an old hdd? They have a finite life time, and the older the drive, the more chances are of it failing, and you losing your data. Maybe it would make more sense to buy a new ATA drive and use it instead?
Good luck, and don't forget to come back with a testimonial if helped :)
SOURCE: MI DISCO DURO SUENA COMO
Not a good sign. You will need to pay to have the data recovered if you need it. Otherwise, plan on getting a new disk and reinstall Windows.
SOURCE: Preciso identificar heads, sectors, cylinders de
run the chkdsk utility
i have found the easiest way for me of doing this is to
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive also download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
hope this helps you
