Question about Fossil Arkitekt Watch for Men
I have a F ossil Arkitekt (fs-2990) that is a several years old. I removed the back and the battery to change out the battery and noticed that one of the numeral bars on the face has dislodged itself. in trying to remove the face from the watch case I cannot get past the knob that adjusts the hands of the watch. how do I remove the face to fix the loose numeral bar?
Posted by wjhegen on
Geoff
    Dedicated:
    Visited the website for 20 consecutive days.
  • 125 Answers
The knob that adjusts the time is called the crown, and it will have a stem attached to it. You will need to remove crown and stem together.
If it's a screw-down crown, unscrew it.
Examine the watch mechanism very carefully while pulling out the crown (as if you were adjusting the time) and pushing it back, What you are looking for is basically anything that moves. If you do see parts of the mechanism move, look very carefully around that area for an arrow mark impressed in the metal pointing to a small dip in one of the metal parts.Often, this is on a tiny lever but not all manufacturers bother with the arrow.
Ensure that the crown is pushed back to it's normal position. Put a tiny amount of pressure on the dip (a needle is ideal for this), and carefully attempt to pull out crown and stem.You may need to apply slightly more pressure to get a result, but please take care not to press too hard or you may damage the mechanism.
Hopefully, that should sort it out. To refix the numeral bar, I'd recommend super glue - but you only need a tiny, tiny amount. Apply it with the tip of a needle and you shouldn't go far wrong.
Once you're looking at reassembly, you should be able to reinsert the crown and stem without depressing the dip but do it gently and don't force it - it may need a slight turn to relocate properly before it slides back in.
I hope this was easy to follow - get back in touch if you get stuck.
Posted on Oct 03, 2017
3 Related Answers
rjnworbnhoj
  • 142 Answers
SOURCE: Condensation
On most watches, if you get condensation within the face, means that there is a small crack on the glass/plastic covering. Some watches you can take apart from the back and pull out the workings and replace this casing, on others, you have to take it to the jewelers to have it replaced. Depending on how much you paid for the watch, you are better off buying a whole new one.
Posted on Sep 20, 2008
Anonymous
SOURCE: how to change day on
just pull the round knob once(very lightly pull it out) and keep rotating for few seconds and the date will change.
Posted on Mar 24, 2009
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: I have a Fossil Arkitekt
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
Posted on Aug 21, 2010
What kind of battery does the Fossil arkitekt watch FS 2905
Find out by removing back, finding battery, and identifying type.
Dec 02, 2016 | Fossil Watches
What battery size does a fossil arkitekt fs-2759 take? Thank you
Just take the watch to your nearest jeweler. They can quickly replace it for you....probably cheaper than what you would pay for the battery yourself.
Mar 02, 2015 | Fossil Watches
How do i set the month on my fs-4250
Google (fossil)(Fs-4250)(manual) without parens for month setting instructions.
Sep 14, 2014 | Fossil Arkitekt watch
What battery goes in the Arkitekt Fossil FS 4313
Take your watch to a jeweler for battery identification and possible replacement.
Sep 12, 2014 | Fossil Watches
What size battery does my fossil fs 2920 arkitekt take
Go to any local Jeweler and ask them to replace the battery, about $8
Jul 12, 2014 | Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
I have a Fossil Arkitekt wristwatch (FS-2919). on of the hands on one of the three tiny dials has come loose and is floating around the face. I probably wouldn't care, but the main watch hands get caught...
Goood luck
Aug 21, 2010 | Fossil FS2919 Wrist Watch
Fs 4159 sudennly stopped working
The first thing to check is the battery.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 25, 2010 | Fossil Arkitekt watch
Fossil Arkitekt Watch for Men Logo
316 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
john h
Ngoro
Are you a Fossil Watch Expert? Answer questions, earn points and help others
