Coby MP-705  Digital Media Player  Logo
Question about Coby MP-705 Digital Media Player
I've explored numerous option to delete specific folders/files from this unit unsuccessfully. When clicking delete the following text boxes appear simultaneously: Error Deleting Folder. File name, could not be deleted. The device has either stopped or been disconnected AND a Deleting text box showing an open folder emptying its contents into a Recycle bin. Within a second or two the unit automatically disconnects. Recently added files are deletable.
Posted by satnamcat on
Anonymous
    Novelist:
  • 149 Answers
Hi, what makes the files your trying to delete is not able to delete is, because the files your trying to delete has been affected by VIRUS and can be able to delete..
You will need to reset the Mp3 player .you can use the manual below for help
http://www.cobyusa.com/files/setupguide/MP705_SG.pdf
Have nice day..
Posted on Feb 17, 2011
1helpful
When I enter subject video photo comes up when I enter I only get white screen
I've seen this problem before and it has to do with Internet explorer cache. You will need to clear the internet explorer cache in order to view the youtube videos again.
You have have this done automatically by going here -- >http://go.microsoft.com/?linkid=9746384 and launching that exe file.or do it manually with the flowing steps:To delete the files in the Temporary Internet Files folder yourself, follow these steps:
  • Windows 7 and Windows Vista
    1. Click the Start button vistastartbutton.jpg, click Control Panel, click Network and Internet, and then clickInternet Options.
    2. Click the General tab, and then click Delete under Browsing history.
    3. Click Delete all, click Yes to confirm that you want to delete this information, and then clickOK.
  • Earlier versions of Windows
    1. Quit Internet Explorer and quit any instances of Windows Explorer.
    2. Click Start, click Control Panel, and then double-click Internet Options.
    3. On the General tab, click Delete Files under Temporary Internet Files.
    4. In the Delete Files dialog box, click to select the Delete all offline content check box , and then click OK.
    5. Click OK.
tip
How to find a lost file on your Computer?
Today tip will help you to enjoy the quick and easy way to find lost files on your computer. Here I recommends you, try to search a file with its file extensions (for example for word file, type *.doc, Excel *.xls, Acrobat *.pdf, *.ppt and *.exe for executable files. If you don't know the name of file but know that it contains a string of text then try to search for files containing specific text, type the text you want to find from any file or folder. This is time taking process but creates very precise result. In Look in, click the drive, folder, or network you want to search. To save time, always select the specified drive or location instead of whole computer.
Click Start Button, point to Search, and then click For File or Folders, a Search Results dialog box will appear. In Search for files or folders named, type the file name or folder name you want to find in containing text.
To specify additional search criteria, click Search Options, and then click one or more of the following options to narrow your search:
  • Select Date to look for files that were created or modified on or between specific dates.
  • Select Type to look for files of a specific type, such as a text or WordPad document.
  • Select Size to look for files of a specific size.
  • Select Advanced Options to specify additional search criteria.
  • Click Search now.
2answers
Only one website is stuck in spanish how do i change it back to english. i have already tried 2 ways and niether work
If this isn't a "User Profile" site like "My Yahoo" / "My MSN"/ or a forum.
Try this:
Open Internet Explorer.  Then go to Tools' Internet Options, and then the Advanced Tab.
Reset your Internet Explorer settings with the "Reset" button.
Download this little guy:
http://www.atribune.org/index.php?option=com_content&task=view&id=25&Itemid=25
Run All Temp Files cleaner with all options selected.  This will clean out all cached files.
Reboot your PC, and try again.
3answers
It runs really slow and will freeze up. Ran a virus scan and nothing shows up. Ran clean up a defragment and upgraded the memory. nothing works.
YOU CAN PERFORM A FEW MORE STEPS
Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
RUN DISK CLEANUP
DELETE TEMP FILES
1. Click on Start and then Run.
2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
DELETE PREFETCH
2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Prefetch folder , Remove them.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
Download Revo Uninstaller: http://www.revouninstaller.com/download/revosetup.exe
AND REMOVE UNWANTED PROGRAMS
DOWNLOAD CCLEANER CCleaner can be downloaded from http://www.ccleaner.com/ AND RUN IT
CREATE A NEW USER ACCOUNT
4helpful
2answers
Can't log on to Facebook. It's been like that for the past 2 days. Each time I try to enter my email and password it just comes up with the screen that says it is incorrect and I need to check that CAPS...
Try logging in on a different computer, and if this is not possible, then your account may have been deleted. To attempt to resolve this issue you can scroll down to the bottom of the page and click "help". this button should be at the very bottom left hand side of the page. Once the next page appears, view the possible problems and follow the directions. Any further problems send me a message back so that i can finish helping you with this problem.
I cant log out of facebook
Try deleting your cookies. Use one of the below options: How to manually delete cookie files in Internet Explorer 8 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 8, and then exit any instances of Windows Explorer.
  2. Do one of the following:
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER
    • In Windows XP, click Start, click Run, type inetcpl.cpl in the Open box, and then press ENTER.
  3. On the General tab, click Delete under Browsing History in the Internet Properties dialog box.
  4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the Cookies check box.
  5. Click Delete.
To verify that the cookie files are deleted, follow these steps:
  3. In the Internet Properties dialog box, on the General tab, click Settings under Browsing History.
  4. In the Temporary Internet Files and History Settings dialog box, click View Files. This opens the folder where your cookie files are stored.
  5. In the folder that you opened in step 4, verify that there are no .txt files.
How to manually delete cookie files in Internet Explorer 7 loadTOCNode(2, 'moreinformation');
  1. Exit Internet Explorer 7, and then exit any instances of Windows Explorer.
    • In Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg, type inetcpl.cpl in the Start Search box, and then press ENTER.
  4. In the Delete Browsing History dialog box, click Delete Cookies.
  5. In the Delete Cookies dialog box, click Yes.
To verify that the cookie files are deleted in Internet Explorer 7
How to manually delete cookie files in Internet Explorer 6 loadTOCNode(2, 'moreinformation');
To verify that the cookie files are deleted for Internet Explorer 6:
  2. Click Start, and then click Run, type inetcpl.cpl, and then press ENTER.
  3. In the Internet Properties dialog box, on the General tab, click View Files under Temporary Internet Files.
  4. In the folder that you opened in step 4, verify that there are no text files.
8helpful
3answers
Error 8E5E05F6: You can't sign in to Windows Live Messenger
Hi, If you are receiving Error 8e5e05f6 when you sign into Windows Live Messenger 2009, please try the following:
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
7helpful
3answers
How do I fix Error 8E5E05F6
Try the following:
1. A. Windows XP :
Windows XP:
Windows Vista:
1helpful
2answers
Error 8e5e0155
Hi. To rule out your browser's settings as the cause of the issue, please optimize it.
To optimize Internet Explorer:
http://windowslivehelp.com/solutions/accounts/archive/2009/03/03/How-to-optimize-Internet-Explorer-browser.aspx
Hope I helped MSN expert Dr Reed
Personalization don't reflect once restarted or shutdown
http://support.microsoft.com/kb/836914
To resolve this problem, enable the Userdata persistence security setting. To do this, follow these steps:
  1. Start Microsoft Internet Explorer.
  2. In the Tools menu, click Internet Options, and then click the Security tab.
  3. Under Select a Web content zone, click Internet, and then click Custom Level.
  4. In Settings, click Enable in the Miscellaneous section under Userdata persistence, and then click OK.
  5. When you are prompted to confirm that you want to change the security settings for this zone, click Yes.
  6. Click OK to close the Internet Options dialog box, and then close all Internet Explorer windows.
If the problem persists, delete the WindowsUpdate[x].xml files in your UserData folder. To do this, follow these steps:
  1. Close all Internet Explorer windows.
  2. Click Start, click Run type explorer in the Open box, and then click OK.
  3. Locate the UserData folder. This folder is in one of the following locations:
    • Microsoft Windows 98 and Microsoft Windows Millennium Edition
      C:\Windows\Application Data\Microsoft\Internet Explorer\UserData
    • Microsoft Windows 2000, Microsoft Windows XP, or Microsoft Windows Server 2003
      C:\Documents and Settings\Username\UserData
  4. Typically, the UserData folder contains four subfolders. Open each folder, and then delete any files that take the following form: WindowsUpdate[n].xmlTo delete a file, right-click the file, and then click Delete.
    Note You may see multiple versions of these files in the folders. Some of the folders may be empty. Delete all these files that you find.
Top Coby Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
