Question about Wells F-67 21167 Deep Fryer
No green light and not heating the oil - Wells F-67 21167 Deep Fryer
Posted by ayllon_roman on
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Tip
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Instrument-general
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
, i am using yamaha r15 bike .i recently filled up coolant oil on ur advice as my bike radiator is heating too much.But after refilling my coolant oil i observed the coolant oil is leaking(green colour...
green liquid is antifreeze .perhaps you put too much in but some bikes use oil as as coolant not antifereeze best contact a dealer or read your owners manual to see if you put proper stuff in bike
Mar 29, 2015 | Cars & Trucks
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
Jun 18, 2012 | Kenmore Dishwashers
Fan blows but no heat. Green light flashes four times
If the fan blows and green light flashes. When the green light is fix, it means the time is set to start your heat pump. Check your electrical control and wiring for any damages including the terminal lugs, capacitor, or relay. Check also if the thermostat is working. If your heating comes from heating coils, check continuity of the heater wire including the overload. Replace any defective parts.
Sep 01, 2011 | Heating & Cooling
The Orange "ON" indicator light
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
Euro-pro iron. red light on. green light blinks on but iron will not heat up. lights do not progress through yellow (does not go past green) purchased from walmart with warranty extention on 12/08. ...
When the green light stops blinking and is solid, the iron is ready for use. Touch the handle and begin using. but as you mentioned that green light is blinking and the iron is not heating then there is definitely a short in wire some where it has to be checked.most probably its the short in the heating coil wire.but if the heating coil wire is proper and not short then your irons heating coil probally went bad its alot cheaper to just buy a new iron .because heating coil costs near to new iron.but still get confirm if its short in wire. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 18, 2010 | Vacuums
Went to plug in. Green light came on, no heat.
it's posible to have a disconected wire or a heating element burned. also is posible to have a problem whit saftey thermostat. good luck!
Feb 20, 2010 | Cuisinart WM-SW2 Sandwich Maker
We have had our WC1000 coffeemaker for 6yrs and have had no problems with it until recently when the blue light does not go out and the green light does not come on at all. It still heats up the water and...
chances are your pot is a bit clogged with coffee oils. I would run a couple of cups of vinegar through it followed by three pots of water to attempt to remove those oils.
Oct 04, 2009 | Waring Pro WC1000 Coffee Maker
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
Wells F-67 21167 Deep Fryer Logo
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
