The most probable problem is a clog in the hose.
First detach the hose from the vacuum and turn it on. If it runs without the hose, you're on the right track. Detach the hose from the wands and drop a coin in one end. Lift the end so the coin should drop through. If it doesn't, there's definitely a clog. Plug the hose into the exhaust port, place other end into front of vacuum, and turn it on. This usually clears it.
Also check the elbow at the power nozzle. Clogs here are usually visible, but you can hold the PN up to the light to check for a blockage.
If none of these take care of the problem, the entire vacuum needs to be taken to an authorized Aerus Electrolux shop for diagnosis and repair.
http://www.aerushome.com/storelocator/
