Siemens WD61392GB Front Load Washer / Dryer Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to lock and unlock the drum While transportation
Gerry Harvey
Level 3:
Genius:
  • Siemens Master 1,482 Answers
  • Posted on Feb 17, 2011
Gerry Harvey
Siemens Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378786
Points
4533
Normally this is done by refitting the transit bolts ,which are 3 of them to the back of the machine they are refitted by means of a 8 or 10 mm socket or spanner.....Failing that if you do not have them damage can be prevented by Jamming/packing the drum with old towels against the casing and trying to keep machine upright at all times ...Good Luck
Please confirm the shipping lock is unlocked
All question need full 'make model (what it is)' first 3 words.
Ricoh copier? So it shouldn't be in Cars and Trucks category :>D
Shipping lock malfunction - fi-6800 / fi-6400 - PFU - Ricoh
PFU https://www.pfu.ricoh.com > global > scanners > erg
Please confirm if the shipping lock (transport lock) is set to the released position. If the switch is set to the locked position, please switch it. [Locked].
Remove Shipping Lock error message on control panel
Hewlett-Packard https://support.hp.com > ca-en > document
Open the cartridge tray and locate the cartridge causing the message. note: The color of the locked cartridge is displayed on the control panel after the ...
Flatbed motor malfunction - PFU - Ricoh
PFU https://www.pfu.ricoh.com > erg > motorlock-6x
Confirm that the shipping lock (transport lock) is unlocked. If not, release it. [Locked]. Scanning. [Unlocked]. Scanning. If the state is not recovered by ...
1helpful
Transporting bravos washmachine
You need to lock the drums and make sure that the motor and drum does not move too much during the transit as it can cause alignment issues. Make sure that the drum is also transported in the correct position.
How do you remove the old drum?
To remove the drum unit... First you need to release the transport tray ( as if you are removing a paper jam ) also, you need to release the developer unit as if you are going to add toner... Lastly, there is a thumb screw on the front of the copier or one Black screw ( philps head) remove the screw and the drum should pull straight out toward you and install the new drum unit and lock the transport tray & dev. unit and your done..... Good Luck
1helpful
Scanner has racheting noise and red light stays
This noise is caused by the transport lock. Power the scanner off. Lock and unlock the transport lock a few times and then leave it in the unlocked position again and power on.
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
CD tray "Locked"
sorry mlcato, if there are no transportation lock at the bottom then the system has to be opened and unlock manually. if it is possible for you to open the system I could guide you to unlock .
1helpful
Installation
An error occurred when you set the transportation lock to the lock.gif locked position. To clear the error message on the LCD panel, set the transportation lock to the unlock.gif unlocked position, and then turn on the product again or press the fontx1.gif B&W Start or fontx1.gif Color Start button to restart the scanning job.
You can find the transportation lock on the left hand side of scanner when you lift/tilt ADF up. Hope this helps...
12helpful
7answers
Copier Locks up L1 Error Code
there is a locking dial under the left side of the machine that maybey holding the scanner in home position.... be sure its unlocked.
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
