SOURCE: refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
SOURCE: Burnt out relay/overload assembly, compressor won't run.
it can be difficult to get the right one for it, however there are eletronic ones on the market that will do the job.
it could have been caused from the unit cycling off and on to quick, or the compressor drawing to much current
the windings should be tested with a multimeter to see if they are faulty or not
SOURCE: LG GR 349 REF HAVING DEFROST SENSOR NOT WORKING ? cAN WE REPAIR THIS SENSOR
My fridge is not blowing any cold are out and someone told me is was the sensor
SOURCE: the ref technician said that the compressor of
most only need the model and serial number of the unit.ref. freezer
SOURCE: LG model GR-L197NIS Display panel,
There are many reasons that could cause that. and normally, a failure code is displayed too, then refer to this service manual for your model in order to identify the exact cause and therefore solution. hope this helps especially the service manual.
regards
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
6 - DC Peak Error
• Supplied power is not normal
• Comp Connector (CN-U,V,W) is disconnected or inserted to wrong
position
• Compressor is damaged (coil short) ? replace compressor
• Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
