RCA HD61W140 61 in. Rear Projection Television Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 52" RCA
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Feb 17, 2011
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1004507
Points
13534
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
I have a 52 inch rca that after moveing it up onefloorwont turn no green it worked downstairs
Is it a projection set without a model number I can only make a guess. If your using "component cables' on it, one of them isn't plugged all the way in or the cable broke while unplugging it, swap out the cble and let me know. Thanks Techman 57
52" RCA Rear Projection TV- When turn on the screen seems to be split in 3 horizontal bars all scrolling. The color doesn't seem to be there either, but hard to tell. When I put up the menu
Good Morning
if you remove the signal either being HDMI or Av Cables from the source are the bars still there ? if they are id suspect a signal board problem . if there not try unplugging your signal source for 5 min's and then do a restart if problem still exists then contact your service provider for further assistance .
Screen says weak signal
try to unplug the unit and let it boot back up or check with the provider
Model rca r52wh74yx50
Consult owners manual for channel programming. Channel program sequence may be interrupted by weak or drop out of chl 11 signal. This happens occasionally when signal is from standard antenna
RCA Scenium HD52W140
I cannot think of anything easy that would cause the symtoms you are describing. Your power supply is working and the deflection bd is good because you have HV. The problem is signal related and all of this circuitry is on the SSB or small signal bd. The difficult thing is when replacing this bd. you must have RCA's chipper check to download all of the ssb eeprom settings so they can be uploaded to the new ssb. I'm affraid you will need a qualifier RCA service tech for this problem.
2answers
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
2answers
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
