Question about Hitachi 61SWX10B 61" Rear Projection Television
Magic focus is not working. red lamp is out of focus.
  • Hitachi Master
  • 8,617 Answers
The convergence repair kit for your model is available at www.tvrepairwporld.com which should solve that problem. The kit does include the parts and the CD with instructions for the repair.
Posted on Feb 18, 2011
5 Suggested Answers
BMW Rider
Larry Eastman
  • 232 Answers
SOURCE: Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Posted on Dec 14, 2007
Vista Electronics
  • 1694 Answers
SOURCE: Magic Focus does not work.
Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
with upgrade Stk394-160E Hitachi part # CZ 01341,change both
for reliability.....check B+ feed resistors for over-heating....T.
Posted on Feb 04, 2008
fancyfacej
SOURCE: Red want focus
red will not line up at all did auto focus still nothing what do we do
Posted on Jun 07, 2008
Anonymous
  • 29 Answers
SOURCE: will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Posted on Feb 07, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Colors are not aligned Magic focus ?
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Posted on Oct 02, 2009
Testimonial: "This is just what I was looking for. "
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Picture looks funny and the magic focus is not working
Model indicated cannot have magic focus--it uses a lamp---Confirm actual model number and let me help you. I am here to help.
REGARDS, SD TECH
Sep 10, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
The screen is round on top & bottom ithe face looks like 2 sets of eyes the wods are red & blue
did you bump in to your tv?
your lamps are probably out of adjustment
some tv's have a "magic focus" button that automaticly adjust your lamps
check your tv setup
Jun 26, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Will not show red color in picture, magic focus shows red though
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Plenty of Sound, No Picture
You may have to replace the convergence IC's or the lamps. Impossible to say without having a manual inspection. Best bet is to take it in for a service repair..
Sep 27, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Model c50-fd2000 multi-system has got way too much green, magic focus not helping
How do I replace the lamps? My TV will not turn on. The powere lamp is green for only a split second then it turns red. Maybe one of the lamps is burned out????
Jul 03, 2008 | Televison & Video
Out of focus
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 61SWX10B 61" Rear Projection Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
