Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
We got a sandisk cruzer micro flash driver, pluged in to the usb port and nothing happens. went to my computer the drive is not there. what i am doing wrong. A light comes on the driver then it goes off. i
Posted by cd14418 on
Anonymous
    Scholar:
  • 24 Answers
It sounds like your media is malfunctioning (controller issue).
Our company, LC Technology, is the only Sandisk-approved
data recovery company and we have been working on their products
for over 5 years. You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Sandisk with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Feb 25, 2011
Will Hartford
  • 1,472 Answers
Cd14418
Alot of time all you need to do is assign a drive letter to the device. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Feb 17, 2011
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 2GB cruzer micro USB not detecting
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect sandisk to computer then cehck if still face problem try all usb port of computer.
Aslo check your usb port of computer are working fine.
Aug 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2gb flash drive not responding
Go to "Control Panel>>>System>>>Device Manager.Once in Device Manager,then click on "Disk Drives" (Make sure your flash drive is plugged in before you do this).You should see your flash drive listed by it's name (SanDisk Cruzer...). If you don't see your flash drive listed, the computer is not recognizing it and your drive may have been damaged by static electricity. If your flash drive is listed, then it's a more complicated troubleshooting procedeure than I can Walk you through in one posting. So try looking in "Device Manager" and then let me know what happened.
Jul 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My computer do not recognized my Sandisk Cruzer Micro 1.0 GB.
I had the same exact problem on my 8G card. It worked fine in the camera, but when I plugged it into the card reader it flashed once and then the light went off. So, I put the card back in the camera and ran a USB cable from my camera (there was a port on the side of my Cannon Powershot that was smaller than a USB, but I don't know what to call it) to my computer. When I turned the camera power on, the computer was able to read the 8G card while it was inside the camera. I downloaded everything to my computer at that point. Hope this helps! I got the chord from my external hard drive and that fit from the camera to the computer.
Jun 09, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
SanDisk u3 micro 1 GB Cruzer
hi turn off your pc put the card into the usb then turn on your pc let the pc find the drives for it and load on if this dose not work try the same in another usb port ok
if it works you must format the 1 gig stick befor you use it
ok hope this helps
May 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Nothing happends when I plug my drive into my PC's
Surely you have to install driver first because windows does not have it in cache. If you don't have go manufacturer site
Apr 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
k24674
Marvin
Marvin
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
