Question about Lexmark X6575 All-In-One InkJet Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
Posted by eve_pena79 on
Anonymous
    Novelist:
  • 117 Answers
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Posted on Feb 17, 2011
Can I use only a black cartridge to print on my Lexmark X6575 printer or do I need both?
Hello, Well i think you can, because on my printer i've tried it and it worked for me. All you have to do is try it, but i know is not going to affect your printer in any way.(
I don't know where the ink cartridge goes in my printer
You need to lift up on the top part of the printer and the print carts are under the lid at the top of the printer. You can always visit www.lexmark.com for you manual on how to install print carts.
Thanks and please leave postive feedback and ratings for you free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How do i access the cartridge
Here's an article in the Lexmark website to guide you on how to access/change/replace the ink cartridges in the printer. Since you did not post the exact model number of your Lexmark printer (e.g. Lexmark X6575, Z2420, etc.), I'll show you the general steps. Just click on the link: http://bit.ly/cqxhVx . The printer shown on the page may not look like your printer, however, the steps are the same.
7helpful
Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
15helpful
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
Instructions
1. Step 1
2. Step 2
3. Step 3
Problem with inkjet indicator
sometimes the ink level report does not reflect the true picture. what you should do is see whether it is printing faded or not printing blank. If printin normal you really shouldn't worry. If it were not printing I would suggest you returned it but that is not the case.
14helpful
2answers
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
2answers
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
Some of them do. Try going into the printer properties and disabling bi-directional support. This will not allow the printer to check. HP has set some printers to not function if its disabled, but hopefully yours is not one of them.
Open Questions:
See all Lexmark X6575 All-In-One InkJet Printer Questions
Lexmark X6575 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
Mike
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
