the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
YOu charge it with a samsung phone charger - and a small grey double ended attachment that should have come with it - this plugs into the bottom of the earpiece after pulling back the flap, and the phone charger bit goes into the other end. Alternativeley - there are lots of sites selling in-car chargers for these.
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
There's a small power jack under a tab at the base of the unit. I found it only charges if you plug it into the transformer travel charger. For some reason plugging it in the PC USB port doesnt work.
If the unit is being charged a red LED will light up, turns blue after 2/3 hours when its fully powered up.
