The fuse keeps opening because the problem is more serious. If it did not blow, then more damage could be incurred in the TV. Sounds like you should consult a professional rather than not really knowing what you should be doing next.
Jun 19, 2009 - 13 posts - 9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
means you have a part that is dead shorted after the line fuse, usually a bridge diode, regulator IC or possibly the Horizontal output transistor. Not really something a non tech will be able to find, a volt Ohm meter is required as well as soldering equipment.
Tv keeps blowing fuses
it is due to short ckt in your tv in
1 power supply.
2 horl output section
it is mainly due to
1 switching transistr
2 main fil cap
3 rectifier diodes
4 print short
5 h/output tra.
6 eht transformer
You may have a surge protector called a thyristor that is shorted right on the main a/c line. Or the main power supply has a major nasty short as the bridge rectifier the filter cap or the degusing coil.
