Question about Technics SL-1200M3D Turntable
Own similar SL 1300 Technics turntable and have recently added AT MLa 440 cartridge.The sound is wonderful and yet it sounds just a tad sluggish.Is there anything I can do to rejuvenate the 30 year old player other then add oil to center turntable shaft? (5% pitch is turned up)
Posted by gmetrag on
Morne Olivier
    Guru:
  • 257 Answers
It could be a worn drive belt. Lift the platter oof the machine and check your belt. It may need to be replaced
Posted on Mar 18, 2011
I recently purchased an onkyo tx-nr626 receiver with phono input. When playing albums , I don't get full sound. Sound is clear but not full and loud.
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
Dec 23, 2013 | Technics SL-BD20D Turntable
I recently purchased an onkyo tx-nr626 receiver with phono input. When connected I don't get full sound.
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
Mar 29, 2013 | Technics Audio Players & Recorders
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
Feb 02, 2013 | Technics SL-1200MK2 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
How to lock a SL-1300 turntable for moving.
Use masking tape ...two big stands across the platter and a bit to hold the arm in place and some to hold the dust cover shut.
Mar 21, 2009 | Technics SL-1210 Turntable
Turntable turns, but there's no sound.
Well, the motor itself is completely separate from the sound. The path of the sound is basically
Styli -> Cartridge -> Tonearm -> RCA Cables -> Input Source
I would say start from the beginning. Check your stylus. If it's ok, then that means your Cartridge is probably ok. Make sure you have a secure connection from the tonearm to the cartridge assembly.
There really isn't much else to it.
If you cannot get it to work, I would suggest taking it to a service center for assistance.
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Sep 21, 2008 | Technics SL-BD22 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Technics SL-1200M3D Turntable Logo
170 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
