Question about RTO PT724A 365 Day 24 Hr. Timer/Controller
We are unable to program the timer past the date and time function. There is no cursor flashing, only the colon flashes between the time is entered
Posted by johngibso416 on
Anonymous
You posted under PT724A timer
Contact support at Altronics:
http://www.altronix.com/index.php?pid=9
http://www.altronix.com/index.php?pid=2&model_num=PT724A
http://www.altronix.com/p_pdf/PT724Aseries.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 17, 2011
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Need instructions for a Timex Timer Moder #TE111 (TX12694TA)
To set the timehold down the TIM button until Day flashes, Use +/- to adjust then hold down time until hour flashes..Repeat until set.
To program,
1. hold down prog until the cursor starts to flash at 12:00
2. Press PROG to advance to the day or day group you want to program.
3. press + to advance the cursor to the desired ON time
4. press mode until display reads "on"
5. use the + to move the cursor to the desired ON duration? Clock shows this also.
6. press mode until "off" is displayed. then advance the cursor thru the period the outlet should be off. (stupid to have to do this!)
7. press MODE to select as the ON or OFF period(!)
8. press TIME to exit programming.
9. Press PROG again to program another set of days.
Stupid system.
Good luck.
Dave
Nov 23, 2008 | Hardware & Accessories
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
How do I change the date? I don't have a manual.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Need to set the date and can't find manual--
Try this:
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
RTO PT724A 365 Day 24 Hr. Timer/Controller Logo
123 people viewed this question
Top RTO Hardware & Accessories Experts
Gene Haynes
Terry
Terry
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
