1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
Are you talking about presser foot pressure--the amount of pressure the presser foot applies to the fabric and feed dogs?
Some machines have a dial that can raise or lower the pressure.
Some machines have a screw located at the top of the presser foot bar that can be tightened or loosened. (Unfortunately, manufacturers usually did not include this information in the user's manual.)
Even older machines sometimes have a spring-loaded push-button on the top left of the machine. When pushed in, it collapses the spring that applies less or more pressure to the presser foot. The inner button actually applies the pressure in "degrees" which is regulated by how far the button is pushed in. To release this pressure button, press on the outside ring to release the spring. (Incidentally, it is a good practice to release this spring when you are finished sewing. Storing it with the spring compressed may eventually cause the spring to lose its effectiveness.)
An "E1" message appears on the panel.
Description:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Initially, pls try a reset. This could be accomplish by unplugging the SE-270D from the mains. After an extended period, plug back in and power on normally. In some variations, there would be a reset button/key/switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
I occasionally have the same problem with my White d'Lite 1750c. I turn the power off, let it rest a minute, then turn it on again, and the problem goes away for a long time (weeks, sometimes months). Of course, the settings go back to the default, so note your settings before turning the power off.
Hope this helps. Good luck!
Fran CW
