Question about KitchenAid KEYS750LQ Electric Dryer
Keys750gq0 bought in 1998. never had a problem until today. Dryer wont spin but does buzz or hum. Checked breaker, its okay. Lights on dryer and heat
Posted by rdavis03 on
Tim Whalen
  • 3,074 Answers
More then likely the belt is broken:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Feb 17, 2011
1helpful
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 • Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 • Dryers
The dryer LE5800XSN2 Whirlpool model just quit on me. I bought a new thermal fuse and replaced it but it still has not worked. Any ideas?
Dose it hum or buzz at all ? Have you checked to see if power is getting to the dryer ? heat up at all ?
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
2answers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Duet dryer
be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
May 28, 2008 • Dryers
KitchenAid KEYS750LQ Electric Dryer Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Ekse
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
