Question about Motorola Mobility V551
How can I delete a phonebook entry on a Motorola v551 phone?
Posted by tjscheer on
How do you put numbers into phonebook inan aspera f36.
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes
To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/D1760om.pdf
Aug 15, 2017 | Cell Phones
V551: how to remove unwanted phone numbers
When you are in a contact there should be an options or menu for each contact. Select it and edit and remove unwanted numbers or delete the contact if you want to remove contact entirely.
Mark
Motorola Support
Mar 12, 2015 | Motorola Mobility V551
Need to delete phone entries in the Phonebook
Hi. Not sure if this will help but on my Panasonic cordless phone (different model to yours), there's a button labeled "mute/clear" which is used to clear text when entering text for phone entries. Well, if you scroll through you phone book to the the entry you want to delete and then rather than pressing "Edit", press "clear" and, if it's like mine, it will ask you if you want to erase the entry, and you press "yes". Hope it works for you.
Jun 24, 2010 | Panasonic KX-TG5621 Phone
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
How do i delete pictures in memory of motorola v551
Hello.
Welcome to Fixya.
Its my Honor to Help You Sir.
To Delete Pictures, press the menu button while viewing a picture and select Manage.then choose Delete.
Additional Support:
click below to Download Your Phone's User Guide.(Directly)
Let me know If You Need any Further Info.
Good luck^^
Jul 12, 2009 | Motorola Mobility V551
How can I delete Phonebook Entries in V176 Cell Phone?
no matter if your numbers are on the phone or sim you should be able to see the delete (if u see edit, copy or cut) if u need to. but if not you can always overwrite.... Ex...if Ben is who unwanted just overwrite with Susan.(name & number).
Apr 11, 2009 | Motorola Mobility V176 Cellular Phone
Can't open the phonebook of my motorola e398
Motorola E398/Razr address book disappears/bounces:--Solution
press 1+# (i.e. speed dial #1)
press Menu -> Categories -> Select -> All
Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
Dec 11, 2008 | Motorola Mobility E398 Cellular Phone
Deleting multiple entries from phonebook
select mark all then delete..or delete all entries from phone and sim
Jan 28, 2008 | Motorola Mobility W375 Cellular Phone
Deleting phone book entries
Hi cburke. Had this same problem. go to the phonebook, scroll to the number you want to delete and then press menu. it will take you to the edit screen then select delete, or whatever you want to do with the number. Simple really, but instructions with this phone are awful.
ceobarb
Nov 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V551 Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
