Question about Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player
I have the Apline CDE-102 installed in my car and I was looking to put in the iPod/iPhone adapter. How and Where do I attach the adapter to make it work? Do I have to go back and have that professionally installed too?
Posted by doringrufer on
Anonymous
    New Friend:
  • 60 Answers
Find the aux plug in the back of radio and run the the plug out so you can hook up your ipod or mp3 player they sell them in radio shack ask for the stereo plug in jacks
Posted on Feb 16, 2011
Husband has an apline CDE-102 STEREO. The faceplat says "Interrupt". he cannot change that. How does he fix this error message?
Hello Sandra White,
The term "Interrupt" is just a fancy way of saying Mute. Also if you could provide a bit more information as to what his Radio is doing while it says Interrupt that would be great.
Regards,
Roger
Feb 28, 2015 | Alpine CDE102
Hi, I just purchased an Apline CDE 147 and installed the head unit in my car but keeps making this noise, sounds kind of like a static noise, can you help tell me what I might have done wrong or how can I...
How did you install the head unit? Did you use a wire harness adapter or do it yourself? How are the connections made? It could be several things so more information is needed. Is the sound present with the volume off and coming from all speakers or just one? Does it get louder the more your turn the volume up?
Nov 13, 2013 | Alpine CDA-9835 CD Player
Need to know were the reset button is on my cde- 102 cd player
Remove the detachable front panel. Behind that front panel, there is a small button on the bottom left, which is the reset button! (You'll need a ballpoint pen or something similar to press it)
Oct 15, 2011 | Alpine CDE-102Ri CD Reciever, iPod and USB...
How do I get the clock to stay on, on the Alpine cde-102?
I also have the same question, can any one help? How do I get the clock to stay on, on the Alpine cde-102?
The moment you switch off the system the clock goes off, even if the car is running.
Jul 03, 2010 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Can an equalizer cause hissing
The more ground the better,or check the RCA cables.or to see if the power wire is running any cables that power the inter.
Oct 26, 2009 | Alpine Type-R SPR-17LP Coaxial Car Speaker
How to set up clock standby of cd alpine model cde-102 Like I mean clock will be on when turning the key on
Turn the stereo off before you stop car. If clock is not displayed press display until clock is displayed. Then turn off car, and turn it back on it should have clock up.
Sep 08, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Alpine CDE-7858 external input?
yes there is an adapter cable made for this search alpine aux adapter on ebay they run aprox $30 it will plug into cable on back and give you 2 rca inputs to use for ipod and such...
Nov 23, 2008 | Alpine CDE-7858 CD Player
How do I attach the KCE-422i iPod adaptet to my Alpine CDE-9852?
Very easily, just pull the head unit out. Plug the adapter into the round receptacle, run your cable to a convienient place and plug your Ipod in, switch the source to ipod and listen away. Good luck
-Andrew Hawkins
Aug 27, 2008 | Alpine Car Audio & Video
Alpine CDE-102Ri CD Reciever, iPod and USB Controller Car CD/ MP3 Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
