Question about Panasonic Televison & Video
I have a 52"
Anonymous
    New Friend:
  • 134 Answers
Need model number and blink code at time of defect.
Posted on Feb 16, 2011
  • Anonymous Mar 02, 2011
    The red light on bottom front of tv Blinks 10 times, stops for short time them repeats 10 time blink until unplugged. T.V. works again when plugged in a hour or so. Model # is TH-50PZ80U
Hello I have a 52 inch flat screen Sanyo HDTV Model #Dp50747 I was watching a program on my tv and it cut off . I tried unpluging it for a few days still no picture or sound nothing in the back panel is...
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
White dot in the middle of the screen
you have a bad dlp chip hear a link for you so it will help you to unstay.
how the light eng http://www.youtube.com/watch?v=eyAykjZ3zs4
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
2helpful
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
1helpful
1helpful
CVizio 32" background lamp won't stay on
Ur backlight inverter ic board is dead must be replace.
3helpful
3answers
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
4helpful
2answers
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
1helpful
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
