Question about Whirlpool RBD245PDS Electric Double Oven
Whirlpool Electric Double Oven RBD245PDQ1 stopped working during baking when door was opened then closed. Error code -01 F2 E3 -01. The -01 is followed by 0 F and is in very faint red. The F2 E3 is in bright green. When I push the buttons on the panel they each beep three times expect the BAKE button does not beep.
Posted by Richard Gillespie on
  • Richard Gillespie Feb 16, 2011
    How do I add payment info?
  • Richard Gillespie Feb 17, 2011
    When I click on "Claim my solution" I do not get a screen to enter my payment info or view the solution. What am I doing wrong?
Anonymous
    Master:
  • 713 Answers
Your fuse is bad replace fuse.
Posted on Feb 16, 2011
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
F2 error beeping make it stop
F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 22, 2010 | GE Profile JTP56 Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
My Whirlpool gold double oven displays the code F2E3 on the electric panel This problem occurs when I attempt to set the oven to bake. It is now a permanent display
F2 E3: Key held down too long or key is shorted.
Check keypad connector for firm connection. Press Cancel, if error returns after 60s replace keypad.
Jun 28, 2010 | Whirlpool GBD307PD Electric Double Oven
E-3 error code on both ovens
this may be a repeat, previous attempt to respond didn't seem to work....
F2-E3 means stuck key, which probably needs a new keypad ... you can try to unstick by pressing each button a few times, may give temporary solution
F3-E3 means oven overheated in self-clean, could be bad temperature sensor or welded relay on the control board
Best Regards,
bruce
www.fixyourboard.com
Jun 18, 2010 | Whirlpool GBD307PD Electric Double Oven
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
F2 E3 error code- Oven won't turn on now
I ended up calling a technician to come out and look at it. He said that the front panel where you push all the buttons went out and I would need to get a new panel.
Feb 17, 2009 | Whirlpool RBD275PD Electric Double Oven
Oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Dec 10, 2007 | Whirlpool GBD277PD Electric Double Oven
Whirlpool RBD245PDS Electric Double Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
