SOURCE: MICROWAVE DOESNOT WORK TIMER AND LIGHT WORK
firstly check your fuse by the magnetron if its right check check the diode by the capacitor and still not working the magnetron
SOURCE: Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
