Question about HP LaserJet P3005 Printer
What causes an error 49,2F9D on a HP LaserJet P3005N Printer
Posted by jackson_gord on
Stuart Smith
  • 152 Answers
49ErrorsSupport
Troubleshooting for 49 related errors
Posted on Feb 24, 2011
Hallo, How do i clear the error "cannot duplex close rear bin" from my HP Laserjet P3005n
Did you try to open and close the toner door after you closed the rear bin?
Mar 03, 2017 | HP LaserJet P3005n Printer
Hp laserjet p3005n 55.04.92 dc controller error
I need help,my printer are hp lj 3035,the error is 55.04.92-DC CONTROLLER ERROR,how to fix this erroer?
Feb 21, 2012 | HP Hewlett Packard LaserJet P3005n Printer
I would like know the method for edit error of hp laserjet P3005n error 57.03. Please suggestion or method for edit to me Thank you .
Hello Niramon,
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified during device power up. Fan operation occurs only during power up or during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan. Verify that the fan is connected to connector J512 on the ECU PCA. You might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
Jun 13, 2011 | HP LaserJet P3005n Printer
Hello thanks for using FixYa
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below if it is helpful
    THANKS & Keep Using fixya
Feb 16, 2011 | HP LaserJet P3005 Printer
49,2f9d how to slove this problem this is hardware problem or softwware problem
This is a firmwere error for firmwere go www.hp.com/support/ljp3005 for letest firmwere download & install.
If problem persists then replace the formatter card.
thanks.
Sep 25, 2010 | HP LaserJet P3005 Printer
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
Feb 24, 2010 | HP Hewlett Packard LaserJet P3005n Printer
HP Laserjet P3005N not recognized
http://www.hp.com/cpso-support-new/SDD/main.htm?cc=us&lang=en
This is HP's driver checker,it will check your system and make sure the correct driver is installed.
Jan 08, 2010 | HP LaserJet P3005n Printer
New HP LaserJet P3005n printer and cannot openthe
Push the plate down with anything you can get into the small opening that it will allow you to get into. When you can latch the plate down, it will open. When you do get it down, toss the middle spring, along with the black plastic thing on top. It is the cause of a lot of stress and not needed.
Oct 28, 2009 | HP LaserJet P3005n Printer
4.4C0B error in printer
Hi there try removing the additional memory the test.
Thanks J
Jan 18, 2008 | HP LaserJet P3005n Printer
HP LaserJet P3005 Printer Logo
580 people viewed this question
Ekse
efs_perpends
efs_perpends
