Question about Vacuums
How do you clean the fan blades on a humudifier
Posted by fred_brow309 on
Kelly
  • Vacuums Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
I do this all the time and it works well for ALL types of aluminum fan blades on any appliance.
Use an older piece of Scotch-Brite with soap & water (So you do not scratch up the blades) then wipe it off with a damp rag then a dry rag. Just make sure you do NOT get water in the motor bearings. Place the blade your cleaning below the 3 or 9 o'clock positions to avoid introducing water into the motor bearings. Also do your best NOT to bend the blades in the process of cleaning.
Thanks for Choosing FixYa,
Kelly
Posted on Feb 16, 2011
Very poor suction
Make sure ALL the air passageways are not blocked with any hair, dust balls or other material. If they are ALL clear, then it's probably the fan blade that creates the suction is damaged, maybe a blade or two are broken. It is cheap to buy a new fan blade, but taking the machine apart and replacing the blade would be moderately expensive for a repairman. Maybe you can try to do that yourself. If not, always ask for a complete estimate for the repair, and have it written out on paper before you agree to the work.
Oct 18, 2013 | Dyson Vacuums
Kenmore model 116 is very loud
1) the motor fan blades broken
2) brushrollers has a gumor or other sticky substance,clean it
God bless you
Jun 21, 2012 | Kenmore Vacuums
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
I have a 18 yr old Admiral DH359 demudifier. When I turn on the dial (switch) it gives a humming noise buy the blade does not rotate. After about a minute or two it shuts off because of condenser over...
The problem with your unit is the fan. The engine behind the blades have gotten spoilt hence its inability to roll the blades. Usually when the engine of a fan is spoilt as a result of the coil the engine still tries to move but due to the bad coil the engine hums but does not come to a start. The fan is meant to be the main component which regulates the temperature of the unit if the fan does not cool the unit then the unit will overheat and go off. Simplest solution is to extract the entire fan plus its engine and get ? replacement for it. If you have the required expertise to open and reassemble the unit you can do this yourself otherwise get an expert to carry it out for you. Hope this solution has been helpful?
Jun 23, 2011 | Vacuums
The red light constantly flashes and it's not picking up lint from the floor - almost like there's no suction. I've cleaned it out, still... What gives??
Did you clean out the short hose that connects the powerhead to the body?
One big problem with many uprights is that the fan/s that create the suction are installed in such a way as all the dirt, sand, and whatever go through it before reaching the bag. This can cause extensive damage to the blades, causing loss of suction. Solution: replace fan.
It sounds like there's a clog somewhere, though. You'll need to check any area between the power nozzle and the bag/dirt holder for clogs.
Oct 19, 2009 | Euro-Pro NV31 Infinity Vacuum
Suction
hi!!! clean motor blower blades ,they collect alot of duct and the air in chopped,Good luck.Clean blower fan blades..
Feb 04, 2009 | Electrolux Centralux Vacuum
High squell
hi thanks for the question you probably sucked in some foreign object and it got stuck and its caught in the fan blade dismantle and clean thanks the appliance doc
Sep 16, 2008 | Hoover Vacuums
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
