Question about Yahoo Messenger
I have a problem in downloading yahoo messenger when i start download the following massage come "yahoo messenger is unable to download files needed for installation please firewell setting and retry installation " please help me to solve this problem
Posted by sandeep_inn on
Ali Khan
    President:
  • 2,291 Answers
1.Clean up junk filses.
2.Clean up cookies.
3.Clean up registry errors.
4.Speedup the system.
5.Speedup the startup.
Use Reginout to fix it
Posted on Feb 17, 2011
"C:\PROGRAM 1\Yahoo\Messenger\YahooMessenger.exe The application has failed
Hello!!!
You can reinstall it easily by following below Steps :
1. Download this installer : http://www.filehippo.com/download_yahoo_messenger/download/120679041d997dc3e015bd0898f8041d/
2. Run the Setup and Install it.
3. Start Yahoo messenger from Desktop.
4. Enjoy..!!!
Hope this Helps..!!!
Jul 08, 2011 | Yahoo Messenger
Tip
To sort out your yahoo messenger problems please read carefully this detailed...
<br /> Hallow Friend, <br /> If you have tried restarting <span>your computer</span>,signing in with your <span>Yahoo</span> e-mail prefix (without the @yahoo.com)and your e-mail password without success, and you are sure your caps aren'tlocked and your information is correct, your <span>Yahoo! Messenger</span> connection information maybe incorrect. Follow these steps to configure your connection:<br /><br />Solution 1.) Click <span>theMessenger menu</span> in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Firewall with no proxies" option. <br /><br />Select the <span>correct Internetconnection type</span> and country from the pull-down menus.<br /><br />Click the OK button at <span>thebottom</span> of <span>thewindow</span>.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your <span>Yahoo!ID</span> and password and click the "Sign In" button.<br /><br />The above configuration works in most situations. (However, if you connect inthis way, you won't be able to use the Voice feature.) If this configurationdoesn't work, follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "No network detection" option and then click the OK buttonat the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If neither of the above options work (sorry), you're probably behind a firewallor <span>proxy server</span>that requires you to enter its address. Follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Use proxies" option.<br /><br />Enter your firewall or proxy server's address and port number. Contact your <span>network administrator</span>(if you're at work), or your <span>Internet service provider</span> (if you're athome) to determine the correct firewall and proxy settings.<br /><br />Click the OK button at the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If you try all of the steps above and Yahoo! Messenger still can't connect,contact your network administrator, Internet Service Provider (ISP), or theperson who initially set up your computer to ensure that your firewall and/orproxy settings are correct.<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/messenger/messenger-11.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />Solution 2.) You may have accidently saved your ID or password with errors init. To resolve this issue, clear your cache.<br /><br />For <span>InternetExplorer</span>:<br />Click on: Tools<br />Click on: Internet options<br />Click on: Delete Cookies<br />Click on: Delete <span>Temporaryfiles</span><br /><br />For Firefox:<br />Click on: Tools<br />Click on: Clear private data<br />Check: All the boxes<br />Click on: Clear private data now<br /><br />Now try to log onto <span>Yahoo Messenger</span>. <br /><br />Solution 3.) If Step 1 and Step 2 don't solve your sign in issue, tryun-installing then re-installing Yahoo Messenger:<br /><br />Close Yahoo Messenger<br />Click on: Start<br />Click on: <span>ControlPanel</span><br />Click on: Add/remove programs<br />Locate and remove Yahoo Messenger<br /><br />Download Yahoo Messenger:<br /><br />Yahoo Messenger for Windows: <br /><a href="http://messenger.yahoo.com/">http://messenger.yahoo.com</a><br /><br />Yahoo Messenger for Vista:<br /><a href="http://messenger.yahoo.com/windowsvista.php">http://messenger.yahoo.com/windowsvista....</a><br /><br />If you are still unable to sign in, on Internet Explorer:<br /><br />RESTART YOUR COMPUTER<br /><br />If that doesn't help, here is a link to <span>Yahoo Help</span>:<br /><br />IMPORTANT: If all of the above does NOT solve your problem, here is a link to <span>Yahoo! MessengerHelp Form:<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/help8.html?from_url=http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />For future reference, please note there is a link to Yahoo Messenger Help atthe very top of your Yahoo Messenger!</span>
on Apr 27, 2011 | Computers & Internet
I am unable to download yahoo messenger , it is saying an error when it start downloading "check the firewall settings"
Try to download the yahoo messenger from this link given below.
Yahoo messenger
Or
Let me know if this works.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 18, 2010 | Yahoo Messenger
Unable to download yahoo messenger
download from the folowing link
http://www.brothersoft.com/yahoo-messenger-43827.html
Mar 05, 2010 | Yahoo Messenger
Unable to download and install yahoo messenger 10 because of firewall settings. what settings do I need to adjust? thanks
SIMPLE JST SHUTDOWN YOUR ANTIVIRUS FOR A WHILE AND THAN DOWNLOAD YAHOO AND AFTER YOU INSTALL IT, DONT FORGET TO ENABLE YOUR ANTIVIRUS.........
Feb 02, 2010 | Yahoo Messenger
Unable to install yahoo msn
Check your internet connection, may be your connection encountered problems...always download from your trustful sources website. i think better you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you download yahoo messenger,check it out, may be it blocked your yahoo messenger set up from downloading it.
Try these! Good Luck!!
May 31, 2009 | Yahoo Messenger
Unable to download Yahoo messanger
Try downloading the full version of yahoo messenger straight away using the following link:
http://www.softwarepatch.com/software/yahoo-instant-messenger.html
Apr 10, 2009 | Microsoft Computers & Internet
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
Mike
Abhinandan  Patil
Abhinandan Patil
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
