SOURCE: Toshiba Dynabook satellite T11 130C/5
I can assure you that that part number is out of synch with Toshiba's sequences. Close, but no cigar. Did you buy that from Toshiba direct, or somewhere else. I have a toshiba tecra myself, so I go to their support center when I need help.
SOURCE: Toshiba Satellite A80-127 driver
These are all the Drivers I could find for you.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835418&rpn=PSA70U&modelFilter=A75-S229&selCategory=3&selFamily=1073768663&selModel=835418%7CPSA70U
Just click the link.
Have a spicy day and happy lappying! :)
SOURCE: Toshiba Satellite P105-T2050 - DVD player does not work
You can check the BIOS to see if the drive is recognized and even
attempt to boot from the drive using a bootable CD to verify it is
functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find
"UpperFilters" and "LowerFilters" (and "UpperFilters.bak"
"LowerFilters.bak", if they exist) value under the following key in the
registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
SOURCE: i have problem with my toshiba laptop
Here sir, is the link to your model Toshiba drivers.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998602&rpn=PSAG0U&modelFilter=A305-S6825&selCategory=3&selFamily=1073768663&selModel=1998602|PSAG0U#
SOURCE: driver sound laptop toshiba satellite j11
Hi Friend,
Kindly copy and paste the Link u can collect your sound driver
link is http://drivers.softpedia.com/progDownload/Toshiba-Satellite-A215-S7472-Realtek-Audio-Driver-6-0-1-5433-Logo-Download-41853.html
Once u Copy paste the link u get the page and then click the External Mirror 1 u will get the Download of the Sound Driver
Regards,
Ayyasam
