SOURCE: wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write. You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you. What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving. During the wash cycle, the top half is just sitting still. If this is wrong, please let me know. If this is right, you have a sort of simple fix. Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off. When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there. You can put your finger on the lips and lift it straight off. Then you will see a cap with a bolt in the center. Remove this bolt (7/16" with long extension). the agitator dogs (Sears part #387091) . You should see these under that last cap tha had the bolt in it. Remove the auger (just slide it up and off), remove the dog holding cap. Remove the dogs, but be sure you remember the way they go back in. Next is the tricky part. Take the cap upside-down, and place it back in the auger. Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole. Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator. Make sure the locks and stuff fit right between the two. Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap). If all goes well and right, you should be able to roll the auger one way and not the other. If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along. Good Luck!!!!! Jim
SOURCE: whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
SOURCE: Whirlpool top-loader LSQ9200LQ0
Im no expert, just pretty handy with all things mechanical...hope this helps:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LSQ9200LQ0/Whirlpool-Parts-82574.cfm
