you may need to format the card with a lower file type.
It might be ntfs and the camera might use fat32 file type
formatting is like setting up a library
you put in the isles and then you number the isles in order so you know where to put the books in correct order so you can retrieve the book later.
The same basic principle is used for data storage in that you setup the file storage environment on the card so you can store and retrieve data when you need to.
If you need to retrieve files from a USB storage device, it is as easy as using a dependable recovery program designed to perform USB data recovery. This software scans the sectors of an external device to locate and recover these items:
- accidentally deleted files
- corrupted data
- formatted USB drives
- lost or erased files
You see, a recent USB drive corruption or unexpected power outage can wreak havoc on your data. Even a simple file deletion may result in the loss of something important that you desperately need to retrieve. A USB recovery utility offers a reliable approach to quickly salvage your data. It can easily locate files on a USB device for retrieval. Whether deleted, corrupted, or erased during formatting, this program provides an opportunity to quickly get your information back. This video will walk you through the program.
If you know someone who can disassembly your laptop (for safety refer to a laptop specialist) to remove the storage device hard drive inside your laptop. You can retrieve all your data, you can use an usb external case wherein you can insert your laptop hard drive on it and it will work as your storage device of all your computer files, pretty cool because you can use that storage case in any laptop because of it's usb cable connector function.
Your Memory device may have corrupted or the connectors on either your console or the memory device itself may have broken. I would suggest testing your memory device on a friends console, or if still under warranty sending it to Microsoft for a free repair.
there is a loose part inside it is usually a ribbon.. connected to your device storage and its reader if you can open and return your device try to do so, if not cpntact your device vendor.
Have you tried to SEARCH for any file names that you put into that folder? If the search finds a file name that you placed into the folder, make a note of the location of that file, this should help you to locate the missing folder .... it's generally not a good idea to place large files or folders in the desktop, depending on the Windows version you are running. But try the SEARCH for individual file names that you remember putting into the new storage file. Let us know what happens?
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
